Go 500
Sat Nav
Surely you don't need to know the traffic info anymore than 100 miles away as the traffic situation is changing constantly ,100 miles is roughly 1.5 hours awayOriginally posted by Miniliteman View PostKev,
could you do a little test please with your equipment
Set a destination far away from where you are, say Amsterdam.
Then after it has plotted the route see how far away from the start the TomTom gives actual traffic-info.
Just read somewhere that it only gives Traffic Info for about 100 miles around where you are.
Thnx, Leon.sigpic
If route 1 is blocked 150 miles in, then route 2 was probably better to follow in the first place.Originally posted by GAZ W View PostSurely you don't need to know the traffic info anymore than 100 miles away as the traffic situation is changing constantly ,100 miles is roughly 1.5 hours away
Think Operation Stack on the M20
sorry i simply cannot believe that, the ones i used cost me several hundred pounds at least in wasted fuel and lost time, i simply cannot afford to use a sat nav device, i have four in the bottom of a drawer, total cost was over £500 i would have been better off burning the money as at least that way the money would have given me light and warmth for a short time, horrendous horrendous invention that simply does not work and i tried for a couple of years, if you're happy just being in the same county then yes they work a treat but if you need to be closer than that get a road atlasOriginally posted by Miniliteman View PostMy TomTom with Livetraffic is one of the best all-time purchases!
no i haven't but the problem is i am sooo hacked of with sat navs as they have cost me so much money, a collins road atlas is £15 and it doesn't lie to me, if they worked they would make my working day so much easier but in my experience they don't. if i get the chance i'll try a tom tom but not when i'm working miniliteman, thanks for the tip
the most infuriating invention ever
