Fuel Pump Prices
  • Fuel Pump Prices
    Read this on FB and its true
    Put just one liter of fuel in the tank at you next fill and the price on the counter will be more than the advertised price on the pump
    Makes a big difference when you fill your tank up
    As a fuel retailer I don't understand what you are talking about Alan?
    The pumps/metering units are sealed and testedby trading standards.
    A modern pump will transfer via a data cable the value on the display to an input into the till.
    But then again, if its on FB it must be true.
      Must admit I seen this aswell and il be trying it to see if it's true or fb fake
        I was a sceptic but tried it my self and its true
        FB related to a garage in cambridge and I tried it in Newmarket
          "Like"
            This is why ,,,
            Pumps are designed by the manufacturer (and enforced by the regulator) to be accurate at or above the minimum amount, which is typically two litres
