as above do you leave the battery leads on when you connect the trickle charger or do you take them of
trickle charger
if its a smart type charger , i have a meta type used to have it on my varadero , it comes with a small harness that stays on car and just clips together then yes i would leave them connected , a normal battery charger i would disconnect , aldi do a cheaper version a bit like a ctek charger that seems to get good reviews, jim
