As the buying dept is out and about would like some thoughts and feelings on suspension, want to retain standard ride height, dont mind the car being sprung a little more aggressively want the best i can get, what would you recommend,
Advice please
Got fed up with my sloppy rear standard suspension, bought some new single leafs 130lb from Burton along with a pair of Bilsteins. I'm keeping the standard ride height for now but you may want to consider 1.5" lowering blocks. As for the front, uprated springs -1".
Needless to say, polybush all round - this should retain a reasonably comfortable ride whislt give you a bit more cornering stability.
RSOC Member - 6960
