Seeing as Pushrod started this !!!!!!!!
  • Seeing as Pushrod started this !!!!!!!!
    I know how long it will take Google to give you the answers so lets see how quick you can answer the following
    Technical General Knowledge Quiz !
    Q1. What is measured in "Dwell" ?
    Q2. When is an inlet valve at its most open - ATDC or BTDC ?
    Q3. What is the formula for cubic capacity ?
    Q4. What is "overlap" in reference to a camshaft ?
    Q5. What is 1 bar in psi ?
    Q6. In relation to a 175/70 x 13 tyre and a 185/60 x 13 tyre @ 30mph what is the effect on the speedo reading (consider a 175/70 will read 30mph) ?
    Q7. Does a brake adjustable bias system increase or decrease brake fluid pressure in relation to the front brakes ?
    Q8. Does anti-freeze increase or decrease the boiling point of engine coolant ?
    Q9. What is meant by Hydroscopic ?
    Q10. Why is a vehicle fitted with a differential unit ?
    Thats 3 minutes !
      Re: Seeing as Pushrod started this !!!!!!!!
      Rotation of cam
      ATDC
      Must be something like :
      PI*(SQR(R))*STROKE
      When both valves are open for a short duration of time in cycle
      15
      There will be a 4.2% difference i.e. If you are actually travelling at 30mph with a 185 tyre on, the speedo will read 31.25mph
      It can do either, depends how you have it set
      decrease
      can absorb moisture
      Allow two driven wheels to rotate at different speeds
      RSOC Member - 6960
        Some good answers there !
        Anyone else ?
          Time, ie time between tdc and beginning of atdc
          atdc
          Something like .7 or .8 x bore(cm) x bore(cm) x stroke(cm) x no. of pots
          Duration both valves are slightly open
          15 and a bit
          Should be fairly equal.. poss a tad higher.
          Pressure should be as is to front, pressure to rear should decrease if set for front bias
          Raise
          Absorbs moisture
          Allow both driven wheels to rotate at a different frequency
          Paul
            don't you mean "hyGroscopic" Dave? he he!
              isnt a bar 14 psi?
              http://theplateman.com/ - euro/german plates
                I thought antifreeze increase the boiling point.
                1 bar = 14.5 psi
                  NO !
                    NO ! !
                    Originally posted by http://www.newton.dep.anl.gov/askasci/gen99/gen99896.htm
                    As far as I am aware and can find in dictionaries, there is no word "hydroscopic."
                      its defo Hygroscopic
                      as in brake fluid aborbing water
                        ssssshhhhhhhhh
                        Now look what you have done !
                        Given one of the answers - lol lol
                          7. and 8. are easy, too. The answer is "YES" in each case!
                            The number of degrees rotation of the distributor that the points are closed
                            ATDC
                            Pi R sqrd x H (x number of cyls)
                            The time that both inlet and exhaust valves are open
                            14.8 psi
                            A 185/60 wil read higher than the car is travelling
                            It does NOT affect or touch the front brakes !
                            Increases boiling point
                            Absorbs water/moisture
                            To allow wheels on an axle to rotate at different speeds
                            Hope this helped on some basic questions ?
                              He he Dave, you didn't answer Q7. A brake adjustable bias system does increase or decrease brake fluid pressure in relation to the front brakes.
                              Q10: A diff also allows the front and rear axles to rotate at different speeds - ask a Quattro (or Cosworth 4WD) driver.
                              A good effort anyway and I liked the idea. How about for the next one "what does castor, camber, and toe-in affect?"
