Can anyone recommend
  • Can anyone recommend
    My engine has now been sent off to a local specialist, to be stripped down and checked over, ive decided to have the unleaded conversion while its being done, so the engine can be detailed, can anyone recommend a place where i can get all new bolts and studs for the manifolds, ive managed to get a brand new alternator and water pump, are the thermostats still available ??
    Exhaust and inlet studs / washers / nuts are still available from ford , or they was earlier on in the year as i had all new ones
      ian the studs for the manifold are still available from ford ,i would think most of the other engine bay bolts would be too.you can get a thermostat cover as i got one not long ago but it will be alumimiun,not the original metal one that rusted away anyway
        I also had the brand new manifold studs and nuts from Ford
          using beetle studs on mine. no probs. can get you them dead cheap as well
            Cheers chaps, thats good to know
