Ceramic coating manifolds.
  • Ceramic coating manifolds.
    Hello, Has any of you got this done and how good is it. Also has any one used Extreme Temperature Coatings in Perth UK. I think that there Q coat Base colour looks good for the manifold on an RS2000. Thanks Paul.
    Had mine done on the n/a cosworth manifold by zircotec, and it was not what I was expecting , I thought this would be as hard as iron , but to my surprise its like talcum powder painted black and marks so very easily.
      Hey Paul, got mine done by Camcoat, after 3years it's holding up well .
      Camcoat Performance Coatings
      127 Hoyle Street
      Bewsey Industrial Estate
      Warrington
      WA5 0LP
      Telephone: 01925 445688
      Fax: 01925 444988
        Had my Focus RS Mk1 Tubular manifold and Sportscat done by Zircotec.
        It is a white finish as standard, if you want black, it is just VHT they spray over the top of the coating Alex.
        Easy to re-do/touch up.
          127 Hoyle Street
          Warrington
          WA5 0LP
          Fax: 01925 444988
          What sort of money is that?
            I'd have to check Mike, twas 3years ago my memory starting to fade. ) will check at weekend for you.
              I had a TLE Manifold for a BDG done at Zircotec end of last year. Cost was £320
