Night Driving in RRR :)
  • Night Driving in RRR :)
    Went to the local meet last night in RRR
    Bet it's the 1st time it's ever been driven in the Dark
    The headlights weren't as bad as I'd imagined but think I'll still change the bulbs for some Brighter ones. It's the Dials that you can't see Must Change the Dash Bulbs for some Brighter ones. Can anyone recommend any & where to get them from?
    By eck does it shift
    And the Noise Guess the neighbours weren't too happy when I got back in at 11.30
    Just need a few things that need fettling before I'm completely happy
    There's a weird dead spot with the Steering, it seems to turn immediately left but then when you go to the right you seem to have to go through a proportion of 'slack' before anything happens
    Think I'll also get it Laser Tracked to make sure it's all going in the right direction
    And that Diff , not sure what to do with it yet but I've been warned away from an ATB one so I'll have to weigh up other options
    It also needs a complete Nut & Bolt Check just to be sure alls ok
    All in I think this could actually be my 'thing'
    Roll on the Lakes
    Tracking sounds out as Escorts have great steering .
    ATB diffs are the best for road cars so whoever says different is talking shite , lol .
    Nuts and bolts will fall out so paint the threads , use nylocs , use lock wire , use locktight , etc etc . Even the sump will fall off eventually so check the lot !!!
      just drive it,when you get fed up with rattles and bangs take focus out,it will be for sale after lakes anyway lol
        Photos then
          Use LEDs, green I think, remove the blue shrouds though.
          Sounds like the rack or top mounts, possibly the bottom arm(s) ball joint(s). Could even be one of the top mounts loose and the other tight????
          Roll on the Lakes
          Enjoy yRRR Escort
            dash lighting is nothing like as good as a modern car, theres little blue caps around the bulbs, years ago a mate took those out and made it a lot better at night, or just use your satnav or phone speedo app
              lol...they never worked anyway on any escort no point looking at what speed your doing
                With the LEDs fitted (not too bright mind) the dash lighting is brilliant.
                Arguably the dials aren't backlit but it is better by miles than the standard bulb/shroud setup.
                  Yep LED's for dash illumination then very good
                    I guess you're always going to get differing opinions on what's good & what's not
                    Why would you say that they are the best then?
                    Yep I think from what you're saying the Nut & Bolt check is my Top Priority
                    Originally posted by Andyc View Post
                    Photos then
                    Haven't had chance to take it out & get some done yet
                    Will try & get it washed & take some over the weekend
                      Enjoy yRRR Escort
                      Thanks for the advice I will look into the LEDs
                      Again sounds like the Nut & Bolt check is my 1st thing to do!
                      I aim to enjoy it very much. Maybe it was a Trailer Queen but it ain't any more
                      Sounds like LEDs are the way to go
                      Satnav's an idea but would really like the dash to be more visible at night.
                      Originally posted by GAZ W View Post
                      Looks like LEDs are the way to upgrade the Dash Lighting
                      Thanks for all the Advice
                        In a fast street car you need a slipper or else one wheel will spin up and you'll go nowhere . You have the choice of an ATB geared diff or LSD plate diff . The ATB is silent so ideal for a road car and it requires no setting up or expensive oil . They are also maintence free .
                        The plate LSD is noisey and harsh in comparison and more suited to rally cars which get airbourne and run on 3 wheels etc . They also need setting up and expensive oil , rebuilds etc etc . If you like going clonk , bang , clonk allday whilst out for a drive then they are fine , lol .
                          Catch youself on. Don't buy an old school and put in LEDs.
                          Why buy an old school an make it modern.
                          It's like wearing a wig!!
                            i 2nd that
