ive got a: ford 1600 sport. - its wont start *cries*
ive done NOTHING new since it was last run 2 days ago, the key turns all they way to ignition... but nothing happens. ABSOLOUTLY NOTHING
do you recon its the starter motor? - ive tried moving the car back and forth in gear to loosen it, but it does nothing...
the battery has charge before you ask... light and eveything works. never had this trouble before...
please help me !
Jono
please help me !
Jono
it will be bolted the the other side of this engine on the right hand end nearest the the clutch if that helps
