took LAR to work today to do a oil & filter change as its easier on the ramps.
Anyway got home parked her up on the drive and had me tea. Went out about 8 to put her in the garage and i could see a pool of fluid from behind the o/s rear wheel. Oh no I thought leaking wheel cylinder although the substance didn't feel like brake fluid. Anyway to satisfy my curiousity I jacked up and removed wheel, drum and found it absolutely bone dry in there. Shocker also dry.
Only thing i can put it down to is bloody CAT ****
outside of the wheel was dry so the bloody thing must have gone under the car and sprayed its load all over the inside of me wheel.
Still at least the brakes are ok
