Was changing the front two tyres so jacked up on the front cross member.
Took both fronts off, but before i left the garage thought that the trolley looked a bit dangerous with the handle sticking out the front of the car. So I removed the handle and threw it at my arse where no-one could trip over it.
Tonight I went and put my new tyes on, well pleased, job, done.
Went to let down the trolley jack and realised the bit that the handle goes into has sprung straight up inbelow the front spoiler.
Big problem. I can't pull it down as I've no leverage and if I chisel the trolley gearing to let the handle down the upright handle spud will crush the front spoiler.
Just went off in a huff and kicked the cat.
i went and borrowed another jack and jacked it up enough to release the original jack.
If you dont have access to another jack try and get a flat head screwdriver doon the hole and a wee turn anticlockwise to open the valve should let the puppy down gently. You can do it so far on to a stand and then reset the jack again so the handle part is out of the way of the front spoiler before you let it back on to the deck again. Job done m8.
