As i know you all like some pics here is a few of my new engine install which should please at least 1 member Mk1gaz lol still messing around trying to get it set up but have it booked in next week for a tune with the carbs ,hope you approve
n/a cosworth
Oh yesssss!
Whats the spec mate?...should sound the nuts im sure
Built it myself with the head ported by Wilcox engineering ,bored out 92mm h/c accralites ,newman cams + double valve springs ,lifters lightened flywheel to suit t9 gearbox ,tony law ex manifold ,45dcoe webers ,bestek ignition . just using wet sump from rs2000 along with engine mounts to keep her comfy as Gaz says had her out and has a bit of grunt to say the least but needs setting up carbwise as jetting not just right , Wullie
My Blue one is booked in on Wednesday to get the carbs set and balanced done around 2000 miles now with the new JEM engine but the carbs need a wee tickle just to keep it runnin sweet. Hopefully see your car at Knockhill later on in the month. Should be quick now your running n/a cossie anyway i will speak to you soon
Stan
Looks the nuts fella , the best mk1/2 Escort engine conversion for sure . BAAAAAAAAAAAAAAAAAAARRRRRRP BAAAAAAAAAAAAARRRRRRP !!!!!!sigpic 2.1 ATMO YB POWER .
Originally posted by BIGYIN77 View PostBuilt it myself with the head ported by Wilcox engineering ,bored out 92mm h/c accralites ,newman cams + double valve springs ,lifters lightened flywheel to suit t9 gearbox ,tony law ex manifold ,45dcoe webers ,bestek ignition . just using wet sump from rs2000 along with engine mounts to keep her comfy as Gaz says had her out and has a bit of grunt to say the least but needs setting up carbwise as jetting not just right , Wullie
Thanks gents ,hope to get her up and running sweetly shortly and it doesnt half BA*******RRRRP B*********RRRRP Gaz lol ,going to see Lawrence next wed Stan might see you then and davy hopefully ready for the sw blast soon bit more to do but shes gettin there ,cheeRS Wullie
