My reason for not being on track Sunday afternoon @ Croft !
    i run liners gaz - 550bhp standard bottom end....(rods crank)
    Revs to 9k....
    Done a lot of miles....LOL and its fast
      Originally posted by cossie si View Post
      Ummmmmm Dohnuts!
      Heard you had trouble with your ring as well this weekend dave
      ahhh thats why he needed to get some clothes....he told me he forgot his overnight bag
        without a flange, what normally holds a liner in?? just an interference fit???
          , should have seen his 0 to 60 , turbo power has nothin on daves arse power, bit of an oil slick left behind though
          Hefty is the new slim!
          Bald is the new bushy!
          Muddy is defo the new shineeeey! (Copyright Grum 07)
          48's are the new bike carbs !
            Revs to 9k....
            Liners in my cossie too!
              They should have a step machined into the block at the crankshaft end . They freeze the liners in liquid nitrogen so they shrink and then heat up the block so it expands . Then they drop them into place and the liners fall into place and rest on the step . Once the temperatures equalise the liners are jammed into place and can't move (well that's what they told me)
                Revs to 9k....
                What size bore have you got as i couldn't find anyone to liner mine at 93mm with cheap liners . As i wanted all four done they could only do a smaller bore size . Only Julian Godfrey did 4x 93mm liners into a block but his are Nikasil motorsport jobs and therefore cost alot .
                  UPDATE
                  Block out and stripped
                  It appears there is a step in the bore but when the liner was fitted it was NOT pressed home to the step
                  When the liner slipped it stopped at the step
                  So the gap you see on my pic is the amount the engine shop (nameless at this point) did not go down to with the liner
                  Off to see them Monday
                  BUT
                  Thanx to RoddeRS I now have a standard bore 200 block today so in the words of Arnie - I'll be back - lol
                    well it was going well
                      Just had my replacement 200 block back after being chemically stripped and checked for cracks
                      Off now for machining to 94mm and retest to check block not porous after boring it out
                        Are you linering the new 200 block or just doing a rebore ?
                        • #27
                          Collected block today and all appears fine after boring to 94mm
                          Decided to allow an experienced engine shop do the boring and the operator said that when cutting a bore and the wall goes thin the "note" of the cutter alters and he didnt hear anything to worry about whilst machining my block
                          Lets hope it all holds together this time
                          • #28
                            Did about 15 miles in car today
                            All sounds well
                            A few more miles in the morning then on to the trailer to go off to Castle Combe - yeehaa
                            • #29
                              All sounds well
                              where's everyone staying Dave ?
                              • #30
                                Within the Combe circuit
