Why Chesney should be banned from working on cars......
  • Why Chesney should be banned from working on cars......
    The lad really has no mechanical talent at all........ His idea of wheel balancing.....FPMSL.
    nobster it needed some weight, the other 3 balanced up fine, think the rim may be slightly buckled, anyway it drives ok now
    what happened to the caravan stands son pmsl
      Stop trying to change the subject...........
        Get all that lead weighed in and you will be able to but a new alloy lol
          Did you get a proper mechanic to do those????
            theres more lead on there than filler in your roof frostie
              i was shocked when i saw this
                looks like someone's used that alloy as a scrabble board
                my car in the vBGarage
                ***Don't Fool With The Old Skool***
                  I have just calibrated our wheel balance machine and will redo that one tomorrow, i'll let you know how i get on poo pants
                    Now the other 3 will look like that one ....... Pmsl.
                      It makes no difference if it's buckled you nobber there is still the same amount of metal in the wheel, it's not like you have to replace what's missing is it lol
                        I very much doubt it is buckled. It's the bent person trying to balance it that's the problem lol.
                          i thought he only sold parts not worked on anything ...?? no wonder subaru are going down the pan .....
                          PAUL
                            nearly as bad as you kev
                              FPMSL says Mr Expert Mechanic....
