project today has been to fit a pair of rallye design rear single leaf springs into our mk2 escort estate, as after 30 years she was running a bit on the low side more so when she was loaded with the Gardeners gear.
I would recommend a set of thease springs to anyone on the BB cracking fit and well worth the money
The taper is spot on
So is the width
30 years and the front bolt still look as new
so does the bottom plate
Old springs still have there grey primer on and the centre bolts came out with no problems and were used in the new springs
Rubber sadles were ok and went back in too car now sits just right
so imo the springs are very good value I might try a pair of multi leafs in the mex next year
Rally Design now have available in stock:-
Multi Leaf Slipper springs (160lb, 50mm wide) £49.50 each plus vat
and
Single Leaf springs (146lb, 60mm wide) £45.50 each plus vat
Click to both here http://www.rallydesign.co.uk/advance...leaf&x=10&y=10
So is the width
and
must be the fan sucking in tobacco fumes
