failed!!
  • failed!!
    im running a bit behind,havent got rs tested yet.took it today after bin off road 6 months.failed emissions badly.think its to do with just moving it in n out of the garage every other day n its got choked up.hoping a thrash out should cure it .any body else had similar probs??
    Dont worry a quick blast upto Cropton will clear her out,and a new set of plugs
      dnt think cropton will be enough,maybe dalby forest after just to make sure!!
        give it a good service, all oils airfilter plugs, this will bring emissions down
        Old escorts, better than a pension plan.
          cheers,was gonna take plugs out n c what they are like,everything was changed bout 600 mile ago so thought would be ok,worth a try if nothing else tho.
