blimey
    I Will be S*iting Myself
      3000rpm max.........FPMSL.
      nobber
        Flat out then
        I'd rather push a Ford than drive a V**X***L
          bloody hell, less than two weeks. I need to get a move on with my car too
          Alan
            same here...no wheels on my wagon yet
            minilites in the bin and the steels not up to mark
              why's that Miles - would have thought youv'e got the easiest job out the lot behind the bar - make sure the Magners is in Lark
                MOT'd, Taxed, Insured
                Just need the new Water Pump fitted and a new diff oil seal put in once Burtons deliver my collapsable washer
                  I changed mine without a collapsable spacer. Just marked everything and and put them back exactly where they were. But you have to get it spot-on, because there is no turning back of the nut!
                    see "blimey 2"
