lakes saddness
  • lakes saddness
    took the car for the mot today and popped the engine on the way there,loss of oil pressure down to 20psi so i pulled in and had a look.no leaks,on the level with oil,had new ford oil filter and millers 10/60 engine oil changed yesterday.turn't it back on as you cant hear a thing inside with the gearbox and it had a noise from the front of the engine,will take it out tomorrow and get it checked out and repaired.still hopping to make it in my car at the minute but not looking super hopeful tbh.gutted to say the least
    you'll be there - got weeks yet
      get it sorted piglet you WILL be there
        hope you get it sorted in time paul
          get cracking paul, we need to see the car there, bad news tho, good luck
            plenty of time get her sorted
              3 weeks paul, you'll have it sorted by monday
                Best of luck, hope you get the engine sorted out.
                Tim.
                  Tim.
                  Ditto, looking forward to seeing this un
                  Andy
                  If it doesn't break it's not modified enough
                  www.clevelandrsoc.co.uk
                    Best of luck with it mate
                    CheeRS
                    Martin
                      bad luck mate
                      I know you'll make it
                      my engine bay was still in primer this time last year with the engine on the stand and I did
                      Cheers Glyn
                        I also had no engine built this time last years and I made it..
                        chin up, soon sort it
                        steve
                        RSOC Cleveland Group Secretary
                          positivity = success, you'll be there son
                            cheers guys,engine out last nite and took it to bluesprint today,should no the problem by monday
                              Hope you get it all sorted Paul
