my car failed its mot today, nothing bad, a steering rack boot was split, and both lower rear shackle bushes are worn..... i have tried to get the local ford dealer to source some replacement bushes, i dont want to fit poly bushes so i'm keeping it stock......for now. i'm just after any other possible sources for bushes, incase the dealer comes up with nada! burtons dont do them, nor do local motor factors.....any other ideas people?
secondly, the bloke doing the mot said i had a LSD, but i didnt think i did! when the car is jacked at the rear, and one wheel is turned, the other goes in the other direction, (after a little back lash is taken up) but i thought that both wheels would rotate in the same direction if i had an LSD?? can anybody confirm this please, is the something on the chassis plate that will state if an LSD was fitted at the factory???
cheers in advance........lee
sorry!!
