As title, why did I start to fit my WCXM????
Started it last Thursday afternoon, engine was supported managed to undo all the bolts but would the std cross member come off.....NO and as I was running out of time I had to put it all back together but would it go back together again NO
, managed to temp put back together and pushed it back into the garage
Well started on it again this morning, again all bolts came off ok, this time managed to get the std cross member off
and making great time.
Then it went down hill, 1st had to grind a bit of the O/S engine mount as it was hit the exhaust, then bolted mounts onto engine block and went to put the WCXM on, O/S bolts lined up but not the N/S holes
then I remembered others said you have to cut the WCXM holes into slots, did this and had a quick look and all seemed to line up
Put the WCXM on a trolly jack and jacked into place, O/S bolts in ok
but now the engine mount and the bolt hole wouldn't line up
, undid the mount from the block and bolted it the the WCXM then managed to bolt it to the engine and the holes still lined up with the chassis holes so did partly did then up to keep it in place
Now for the N/S, nothing lined up, engine mount to block was off, chassis holes no where near
and to make matters worst one of the threads in the nut thats welded in the chassis stripped all its thread
so I have had to drill the chassis and now have to buy a long bolt to go though the chassis
Again running out of time so had get the car back in the garage so managed to temp get it back together but had to drag the car into the garage under its own power as it wouldn't budge when I pushed it, fecking loud when you have no exhaust on the car and hard work with no steering
Will do little bits each day now as otherwise I'll end up hitting it with a hammer
If I still can't get it to fit I'll dump the 2 1/4" 3 piece exhaust and get a 2" one
