£225 to get it done here -oil is castrol longlife 3 which
retails at £13.40 per litre -your oil capacity should be
8.9ltrs so approx £120 for oil alone plus retail prices to
do the job approx 1hr =£100 makes it expensive but the
labour rate varies around the country
 if your fairly local i could get you the oil & filter on staff discount might save you a few pennies & give custom a tenner to change it
