Does anyone know of a company that will take my engine, strip it, convert it to unleaded, rebuild it and shine it up to concours condition (paint block, powder coat sump, shine up 44s) ready for me to slot back into the car ?
Engine Refurber
Tags: None
Originally posted by KelDave seems to do a good job
a cost to freshen up a Pinto would be labour £225
PLUS !!
Cost of all bits (shells, pistons, gaskets, cam, ARP bolts etc etc etc)
Unleaded seats
Any machining ie bores crank etc
To concours an engine can be the dearest part of any rebuild.
All I did was clean, polish, paint and powder coat what I had instead of buying loads of chrome and alloy etc
Beware - a £500 budget soon becomes a £2000 job
Will give AVA a call first see what they can offerideally looking to spend around 1k tops, the airbox , cam belt cover etc are already being done at the bodyshop with the shell so it is just the bare engine in this budget.
Originally posted by FrazWill give AVA a call first see what they can offerideally looking to spend around 1k tops, the airbox , cam belt cover etc are already being done at the bodyshop with the shell so it is just the bare engine in this budget.
You should get a decent job done for £1k but do the time consuming "silly" jobs yourself and the finished article will be so much better
Chris.
More of Banishit's Handywork!!!
