pinto alloy head
  • pinto alloy head
    Received the new 2009 Burtons catalogue, see the new alloy pinto head advertised within its pages, just wondered whose going to be trying one of these, or has one, does look nice
    andyC is going to get one as he has heard you can fit the manifold on any side
      he'll probably bolt it to the gearbox!
        anybody fitted an alloy diff casing?
          come on guys, none of these parts are necessary on a road car. save your money
            he who dies with the most toys wins
            AKA The Dipstick
              pinto alloy head
              I also see they are doing new alloys sumps, should be interesting!
                diff
                Yes i had one
                Load of money for a diff that screamed.
                Had to take it out.
                Even the company that surply burtons counld'nt set it up !!!
                It seams pinion angle is machined wrong
                Be ok in a rally car i guess,but no good on the road.
                  Originally posted by Darran View Post
                  Yes i had one
                  Had to take it out.
                  I see, I saw once on the Bay, bet it was a f*+* sight lighter than the cast iron job
                  Good to know mind
                    What head bolts do you use with the head ?
                      alloy
                      Good to know mind
                      Early "flow tech " ones all good,if you can find one.
                        ARP Stud and nut kit was used on the ALL Alloy Pinto on Burtons stand at the NEC
                          So a new rocker gasket every 500 miles then LOL....
                          Not the best solution is it
                          Shame that people dont think these things out
