Originally posted by Darran
wheres martin c????
I know you do as i've seen you sliding about everywhere !!!!!!!
lol , it will be fun when the H.P.E. super pinto throws the back end round at 70mph and wipes out half the convoy going to the lakes tour !!!!!!!Originally posted by martin c View PostYup I would never go back to ATB, Plate diff = lots of sideways fun
Martin you best put a block of wood under the throttle peddle (traction control
) or else make sure your reflexes are up too scratch before hitting bumpy , damp tarmac on full throttle whilst gunning it over Ben Nevis !!!!!!
Cracking pic Martin , cool asOriginally posted by martin c View PostBit like this then
Good stuff Martin , you will be spraying rubber and leaving 100 yard black lines everywhere when the H.P.E power is fitted .
Here's it on Video at the Lakes tour
Maybe mate , it's not got much ground clearance though so won't get into those fields/campsites or over the bumpy mountain passes thoughOriginally posted by Tim View Postyou bring your comfty mk1 up to the lakes gaz?
only 1 field and thats at the hotel which is nice and flat to get on with not that many bumps and plenty of lowered cars done the tour,gettin over the ramp was hard for some thoOriginally posted by mk1gaz View PostMaybe mate , it's not got much ground clearance though so won't get into those fields/campsites or over the bumpy mountain passes though
I could get some of those high rise balloon profile tyres i suppose (185/60's) as this would then move the exhaust up another 2 inches from the floor .
