abit naff,anyway you have too many revs,share some out
Naff or neccesity ?
Originally posted by martin c View PostHere's mine
now that looks good as I need to do this with mine the one in teh pic is that the 80mm or the 100mm item from elliot??
Dave dont do the ford racing one it looks very tacky imho.
The other reason I need to do it is that the needle when I use the car is extremely sensitive and ends up bouncing around alot and so has lost its accuracy mind you can this be rectified somehow??
