Originally posted by RS2000CUSTOM
i started the day by doing all the small fiddly jobs, the odd wire here, tighten the odd bolt there, etc things that i could not do while the car was on stands, however it is now on its wheels and the car is setting down, so to speak.
Ref engine, it has not run for four years therefore i left this bit till last. thanks to help from Biker123 (who visits here) we double checked the timing alignment etc earlier in the week.
Yesterday, i wanted to turn the engine over (but not start it) therefore it was on with the filter (yes, i filled the filter with oil first), then in with the Dizzy, and , bearing in mind the wiring has all been re-done and at this point i did not know if there would be any "electrical issues", it was a tense moment that i hit the starter button.
anyway, despite trying, i could not register oil pressure on the gauge, therefore took the cam cover off and turned it over, but nothing coming from the spray bar . Bollocks.
i tried again for a few times (the cam was well lubed prior to this excercise), but nothing.
A call to Custom was needed, and Dave asked did i have a long 6mm Allen / Hex bolt (Yes), did i have a variable speed Drill (Yes) and did i have an extension socket (yes),
anyway, after some turning of the oil pump via the allen extension and drill, my spray bar Ejaculated the liquid gold all over the cam
note the length of the Drive key for the oil/distributor and the extended Allen key (6mm) which i simply cut the end off (the 90 degree bit)
done the job a treat.
with oil pressure done, i could then crack on with loads of other things, plugs in, dizzy set, cam cover on, throttle cables, spanner check, etc etc
nearly there, did not have any petrol, however just off down to get some and hopefully......................
once again, many thanks Dave
