gearbox leaks
  • gearbox leaks
    Hi Guys
    first of all thanks very much for the welcome.Can anyone tell me where to get a set of gearbox seals and rear diff seals her in doors doesnt like oil in her tootsie I told her to stay out the garage!!!! Women. give me ma motor any day.
    cheers
    davie
    Davie,you can still get oil seals and gaskets from ford,just go to a helpfull ford dealer :roll:
      Fords probably David.
      I did the gearbox rear oil seal - really simple job even for me
      Also did the pinion bearing oil seal (or got this done for me more accurately as it's tricky).
      Both seals available from Uncle Henry.
      HTH
        gearbox leaks
        good old henry came through got all the seals i needed
        cheers lads
        davie :grin:
