Fitting Rear Seat Belts......
  • Fitting Rear Seat Belts......
    Hopefully some of you knowledgable gents out there can help me!?
    Bought a set of rear belts off Darran, which came OUT of a Mk2..however, it seems to be beyond my technical abilities to get them back in mine!
    Can anybody give me a steer in words of one syllable, or pictures would be great!!
    Particularly :
    * I have the rear seats out already, and can see that there are 4 pre-tapped holes available..2 on the transmission tunnel sides, 2 on the flat section of the rear "panel". So looks hopeful.
    Which part of the belt equipment goes where? Do the "female" holders bolt to the tunnel, then pop up behind the bottom seat squab?
    Does the reel which holds the belt actually sit beneath the seats (when back in place)? ie can't be seen when all is fitted and working?
    * At the top end of the belts, I think they need to bolt into the C-pillar. Have removed the trim. There are 3 reasonably sized holes to chose from, but none seem to be pre-tapped. What do I do here?
    Obviously, with all this being safety related, and intending that they get used, don't want to do a half baked job on this one.
    Your help would be appreciated!
    Simon
    yes female parts ooo er go under the seat and come up from between the back and bottom.
    The intertia reel goes on top of the rear panel with 2" metal bars with a thread in the centre in the boot and a big bolt from the parcel shelf down and tightened through this bar
    I will post some pics
    cant take the seat out to show you as I have only just put them back in will in really nessary
    before anyone says anything the yellow on the black just rubs off
      Cheers Brian..these will get me on the way!
      Simon
        Bit surprised here! The rear belts originally were fitted vertically and passed through a hole in the parcel shelf with a little plastic trim framing the slot. It's important to know which type of inertia reel you've got and whether it has to be mounted vertically!
        In actual fact on Brian's pic you can see the metal cut out for the belt to pass through. It then goes up to a hoop on the rear C Pillar. Just like any modern car, actually!
          I see what you mean dasadrew, but were done like that gods knows when ?
            Thanks for referring to me as a god, Brian (as I do know when they were done like that!).
            In actual fact, I thought it would be quite easy and original like that, as e.g. the Fiesta rear belts set up can be transferred more or less completely to the Escort (I think!). From an ultimate safety point of view, I'd prefer to be hanging on a 'C' Pillar than a parcel shelf but then I'm a Chunky Monkey!
            Like I say, if you've got the type of inertia reels that have to be fitted vertically, then there's not much choice!
              The plot thickens then....
              I think these need to be mounted vertically then..and now that you've mentioned it, there IS a thin, slotted piece of "trim" attached to the belts. Also, the top of the belt unit is identical to the front seat belt set up (ie the triangular piece which sits just behind the driver's head). So this looks like it would be a good fit on the C-pillar.
              However..how do I attach to the C-pilla itself?...the metal is relatively thin, and not thread tapped...?
              Simon
                Don't believe a word of it!! LOL!
                About 1/3 the way up the C-Pillar from the rear parcel shelf it has a raised flange and a threaded insert. Covered by black sticky tape under the trim.
                Have you looked?
                  Remove C pillar trim and I am sure there is a threaded hole in the pillar !
                    Perhaps I haven't looked closely enough!
                    Tried offering up the fitting/bolt to a couple of the holes in the C pillar, but nothing doing!
                    Sounds like a re-visit tomorrow morning!
                      Had original lap belts fitted into the rear of mine. Mint and for sale if anybody wants them? Need to change to the 4 point fixing ones as described here. MK2 XR2 ones are perfect if anybody has some?
                        This is where the hole is:
                          Just nipped down to the garage (bit wet and miserable out!)..and found the tape circled...lurking beneath, a threaded hole!!
                          Excellent!
                          Thanks for everybody's help then..think I'd better try and do something useful tomorrow then..will keep you posted.
                          Simon
                            belts
                            You found your hole on the c pillar then!!!!!!!
                            The belt real,does bolt up on the inner rear 1/4,in the boot as shown and the plastic trim is to finish off the rear parcel shelf once you,ve cut a hole in it,all the holes and fitting are on most mk2 shells.
                            Banishit has non genuine rear belts by the look of things,as they didnt just bolt off the rear shelf(not very strong),but most kits were done like this at the time.
                            Hope you work it out
                            Darran
                              Some pics of mine (they are mk2 fiesta rear belts) if they help you out
                              CheeRS
                              Martin
