andys other car receives the mr sheen treatment
mr sheen 2
There`s nowt wrong with Mr Sheene,i use it on my fireblade all the time.Attached Files
No porkies, the stuff you can see is a bucket,sponge,tesco own brand wheel cleaner in a proper spray bottle (pink liquid), tar spot remover (black trigger spray), tesco own brand shampoo (black 2ltr bottle),2 sponges and a chammios
Oh and there is a crappy pressure washer just in sight that I was going to use but it doesn't work
Honest, I use MR sheen to polish the car about 4 times a year and It is very very easy and very very good for beading water 3 months later, also dead flys just float off with cold water and a bit of shampoo
All I do is clean the car, dry it then spray on the Mr Sheen, give it a wipe over with a soft cloth and that's it WELL SHINEY with no buffing at all
On dark colours it needs a little buffing but less than a normal polish
Mr sheen has way way more cilicone in it than any off the shelf car polish because car polish enevitably gets washed down the drain or soaked into the ground and the powers that be will not allow any more than a trace of cilicone doing that
And it's cheap at about 60p for 3 or 4 polishes depending on the size of car
yes I have posted up about this before,Difficult roads often lead to beautiful places
