Cut up a Mk2 today
  • Cut up a Mk2 today
    4 door
    Now in about 25 pieces
    Cheers Rob.
    www.RWD-Escort.co.uk
    butcher
      Originally posted by grum View Post
      butcher
      More of a Baker or possibly a Candlestick maker I thought
      Cheers Rob.
        Do you have a boot floor section, I am after a section where the exhaust bulge is and i need a section where the tow bar used to mount on the floor as mine has 2 big holes where the bolts went through..
          Yes I have, the boot floor is quite nice, how far down the wells do you need it ?
          Cheers Rob.
            Hi. Do you have a driver's side rad panel.
            Andy
              It's still on the inner wing at the moment, but it will getting cut off
              Cheers Rob.
                Hi,
                I have highlighted the section needed, Its a bit easier to understand rather than describing it..
                  I'd rather not destroy a good boot floor just for that small piece.
                  If you want the whole thing, then that's OK
                  Cheers Rob.
                    Ok fair enough, how much for whole floor, the trouble is posting a section that size..
                      rob you bastard, i dont know how you sleep doing things like that!!!
