"The" Rocker Cover..now on ...with pics
  • "The" Rocker Cover..now on ...with pics
    Got the rocker cover fitted
    Was a bit of a pig to get the front bolts on the left hand side in
    some pics
    looks great gaz now have to wait till i get mine
    *Edited*
      well done gaz
      i witnessed your handover but didnt have my camera ready
        Originally posted by topaz View Post
        well done gaz
        Someone took a pic of the handover cant remember who it was though
          looks well smart Gaz,
          is the car any quicker with it fitted
            any leaks yet ?
              Originally posted by grum View Post
              any leaks yet ?
              Rocker cover now back off...oil ****ing out
              Put it on by just nipping the bolts up checked for leaks ..loads.. tried tightening the bolts , some oil leaks stopped but a couple wouldnt stop leaking and now i think ive over tightened the bolts and ****ed the gasket ,also ripped gasket taking it back off so a new one on order and will try again
              gasket ony £2.50 Bolts £2.50 and already had an allen key in my socket set so £5 for my fitting kit ...make that £7.50 as i need another gasket
                Get a genuine Ford gasket Gaz, they have steel pins in them either side of the bolt holes so you can't over tighten them
                I just got a silver "Injection" cover from Darran on Sunday .
                £25, brand new, no leaks, uses the wide gasket (with the pins in)
                Car won't go as fast as one with an alloy cover on but it saved me £££££££££££'s
                Cheers Rob.
                www.RWD-Escort.co.uk
                  i only asked !!!!!
                    you should have listened to the wise mr custom yesterday, he had some top tips for fitting the cover's , pm him
                      Did it involve a fire and a 1000cc motorbike ??
                      Cheers Rob.
                        It's just a show-camcover, you have to fit the old one if you want to drive the car. Didn't you knew that????
                          forget about the oil leaks gaz, you dont use it and its always just parked up - just admire it
                            looks good gaz but no good if it leaks, hope it gets sorted fella
                            trailer it gaz
                              gaz,
                              give you £20 quid for the cover
