OHC alloy cylinder head
  • OHC alloy cylinder head
    Would pair up nice with this one..:
    http://www.cosworth.com/shop_item.php?productid=470
    wonder how much lighter the whole thing is compared to the anchor
      and how much lighter would your wallet be
        2.0 Liter Aluminum Head
        Features/Specs:
        - CNC ported
        - Modular / replaceable cam towers featuring line bored 660 Bearing Bronze cam bearings
        - Ceramic sealed water passages
        - 12mm x1.25 spark plugs
        - 4130 oil spray bar with .025 lubrication holes
        - 21.0 pounds lighter than OEM cast iron head
        Included with the purchase of each head:
        -2.0L aluminum cylinder head
        - Complete ARP head stud kit with studs, 12-point nuts, and hardened steel washers
        - Hardened steel washers for cam follower adjuster pedestals
        - Steel spring seats
        - Complete valve job by Elite Engines
        - Complete flow test and verication by Elite Engines.
        $3495.00
          thought the American OHC engine was an inch longer than the UK version ?
            Usa Pinto
            They ran our pinto from 1971 to 1974
            They then ran a 2300cc pinto with 4 cam carriers
            and yes its bigger than the 2litre
              this thread looks familiar.
              oh yes, I've already read it:
                hhhmmm got me thinking !
                Has anyone else noticed the "extra" water outlet port ?
                Its at the back of the head after No4 Exhaust port
                This would remove the "airlock" problems at the back of the head and aid water flow
                This could have a pipe that is then tapped into the heater hose
                  R we sure this is a water out let
                    Looks a bit funny for a 5th spark plug hole
