boring now.
do i put my cibies on...?
Originally posted by RS2000&MEXICO View Posti didn't know that...someone put on here that you have to have them wired up
my bottom 2 spots arnt wired as i dont need them to be. i have 130W bulbs in the tops 2 and they are more than enough!Last edited by pockets; 22-04-2008, 22:26.cheeRS
Originally posted by pockets View Postlook in here, http://www.motuk.co.uk/manual_110.htm (optional lamps).
cheeRS m8sigpiccheeRS paul
I just looked at the books as well Paul, my apologies I was wrong!
Makes it easy now......get the spots on now and leave them on for the MOT !
Still think you should leave them off as they will only get broken when they hit the front of the Trailer LOL
Don't forget to cut your Grill away so the brackets can be fitted easier
you know it makes sencesigpic
Yes Paul, If you are trailering then the spots will catch the trailer bed (As witnessed by Mr Hoarder when I weas trying to load mine up.... )
Also, if you want the steadies to look right then you will need to cut out slots in your nice F O R D grille you have
i don't need the steadies....i'm not cutting my grill....sigpiccheeRS paul
