As i have access to the two cars at the moment i thought it was time to note the differance between the shells on the outside they look the same but underneath they are not
the floor pan on the s/a one has a join the full length of the tunnel
i will just put photos up for the rest and you can ask any questions as it will be this time tommorow if i have to type it all
ps the shiny one is the SA one
batt tray
rad panel
inner wing
front leg rears are the same
bulkhead (exclued the rust)
tank and filler neck
seat mountings
rear seat runner
landing panel
the ones with out photos are
the inner sills only have 4 hole instead of 8
the front panel has a bump out the way on either side just below the indicators
the seat belt mounts are different
no rear seat belt mounts
the centre mount,seat belt mounts on tunnel and reinforcer at rear of gearbox are mig welded rather than spot welded
no jacking points at the rear of the sill
petrol cap
rear exhaust hanger is welded rather than bolted
their is more but it is only holes etc for mounting differnt sun visors and the like
cheers Andy
batt tray
rad panel
inner wing
seat mountings
rear seat runner
landing panel
petrol cap
cheers Andy
