Job done
  • Job done
    Well first time I have seen the RS since they tried to steel it last weekend.
    I have bent the door frame back so it shuts and opens ok and the window can go up and down, but the door is still bent by the door handle so looks like it will need a new door some time this year but at the moment it is useable.
    Put my std fixed 1/4 window glass back in and pushed out the screwdriver dent in the nosecone as much as possible.
    Still have glass all over the inside but that will hover out over the next week.
    I also managed to start it and charge up the battery so the alarm works again .
    Will also have to touch up the paint work due to the screwdriver marks, just luckly for me the car needs a respray anyway so not to worried about that.
    Car is still in hiding until I beef up the garage but its all back together and works.
    The only thing is I have a brown wire under the dash which has been cut but for the life of me I can't find what it connects to, it comes out of the wire-loom and is just the right length to reach the back of the key barrel but there is nothing but a spare spade connector on that and everthing on the car works, any ideas!!!!
    my_car_in_the_vBGarage
    Brown is earth on a Mk2, could be from the door pin switch from the o/s ??
    Cheers Rob.
    www.RWD-Escort.co.uk
      glad you manage to sort it out abit mate shame about the door and screw driver marks though but at least you still have it in one piece
        You are sounding positive at least Kieran . Hope you get it back sorted to your liking soon mate .
        Ian
        Jeremy Schwartz.
          hi Kieran,good to hear your getting it all sorted dude,i see a guy on here yesterday had the same problem,you need to keep a good lookout behind you when going home!
          all the best Edd.
            Nice one Kieron,glad you have sorted some of it
            Proper rallying is done down the lanes!
              glad to hear your positive tones Kieron .
              all the best tim
                good news there, hope the gits stay away for good,
                  God news Kieren
                    Glad you manage to sort it Kieron
                    CheeRS
                    Martin
                      Earth lead, interior light switch or some thing but def an earth!! Be warned cut earth leads are a good way to mute an alarm. FU!KING C3NTS!!!
                        Nice one mate
