pinto book
  • pinto book
    am getin a pinto at the weekend that needs a rebuild and am just woundering wat books are worth a read 2 help wit the build.
    CheeRS Tim
    Dave Vizard's book has got to be the classic one!
      If you going for a straight rebuild then the good old Haynes manual is adequate.
        guna add a few things like cams ad carbs and mayb bigger valves as ther might b a BVH at work
          If y9our thinking of Head work adn cams etc
          You might as well send the head to Karl Norris who did the work on mine and its stunning quality and masses more power
          I have the largest valves that will fit and ridiculous cam but sounds and goes awesome then you can focus on the bottom end at the same time
          Nige
          Heres some pics of the head work
