rs 1600 colour ?
    just found out that the car is marine blue under the metallic blue.
    what i need is a high horse like the others have !
      Morcheen I know we have hijacked your thread slightly.
      But the car you are describing sounds very interesting.
      So it's a genuine marine blue RS1600..?
      I would have thought it would be a special build car.
      Is there a special build plate on the drivers side strut top..???
      As an example, SBO 01 would be bubble arches.
      Also look at the colour code on the VIN tag. The letter Y would state a non standard colour.
      Mark....
        the person who seen the car said there was a plate on that side on the inner wing,slightly bigger than the plates on the slam panel.he was to busy looking at the rest of the car to look at anything written on it.he is quite sure it's marine blue after seeing it on the door shut area.
          Originally posted by morcheen View Post
          the person who seen the car said there was a plate on that side on the inner wing,slightly bigger than the plates on the slam panel.he was to busy looking at the rest of the car to look at anything written on it.he is quite sure it's marine blue in the door shut area.
          If it is a special build car.
          It's those details that will tell you what was fitted at the factory as part of the special build order. The first part will tell you the number it was too.
          Example SBO.152 would be the 152nd special build car to be built.
          Under that number will be several other special build codes.
          See if you can get some under bonnet shots from the guy looking at it.
          Mark....
            have seen some pics of the car off a mobile phone.but nothing to detailed.i will let him know what to look for.cheers M
              MM pm sent ,need to pick your brains
                is there a reg number for this marine blue car
                  is this the same colour as the special build bubble arched rs 2k that was for sale at days of grace earlier on in the year plus i think it was at avo national day ....
                  PAUL
                    PAUL
                      this was for sale on the Bay only a few months back, a low miler too, tasty
                        PAUL
