need to find a good tuner near brum to set my carbs up and stuff ive also got a vernier pulley that i want fitted will a tuner put it on for me or do i have to fit it myself
rolling road
Took mine to John Wilcox. He said to set the vernier up exactly he had to remove the radiator to put all the timing equipment on correctly as by doing it with a protractor isn't accurate enough. Spent all day on it. Since he set it up I havn't had to change a thing in the past 2 years so, generally pleased but £400 lighter Will have it on the rollers again next spring just to see if all is still ok.
