Ref Inner Headlights
  • Ref Inner Headlights
    I had an email back from Valeo
    Sadly they will not do a new run, I even offered them cold hard cash to make a 100+ sets and make sure they were covered, but to no avail the marketing manager said that they make the replacement one without the mounting tabs and gave me the ref number
    So if you cant find any originals then the only option is 2nd handers or outer mounting rings with the new inners,
    I have sent another option to them and await a response
    oh well
    well done for trying - "we need do-ers Brian"
      worth a try bri
        thats what i had to do use chrome rings on inners
          what this will do is make them more scarce, glad I kept my 2nd set
            I have a couple of what I think are inners, in the garage. They say "made in Czechoslovakia" are they correct Bri? The back reflectors are not that good though, but could the glass be put on new back reflectors?
              they don't have "Oktavia" written on them anywhere do they
                lol
                  nice try that brian, good job i aint got a droop snot car, tho the mex lights are hard to find proper ones
                    I just been to look, the "Czechoslovakian" are not the same glass pattern, so haven't a clue what they are off. I do have "Cibie" inners with the correct pattern, also "Hella" with a very close pattern to the "Cibies"
                    Maybe I got mk3 cortina or capri ones as well.
                    But I still wonder can the correct glasses be put on good reflectors? They look like the are sealed on with a compound
                      no good that stu
                      the problem is the backing has the mounts on them, not the glass
                        Originally posted by Banishit View Post
                        no good that stu
                        i was going to say that
                          had the same prob with mine last year no mounting lugs had to drill the little spot welds and glue them onto the new lights still on there fine tho but not ideal
                            nice 1 for tryin Bri.....
                              Are RS flat glass or domed? Mk3 Gt cortina are the same size aint they (flat faced glass) not that you can get them either just put BMW units in me Mk3 but the locating lugs are missing is that the bit you are on about (little square lugs in the rear to stop the light turning round) ?
