Gaz W's rear brakes question
GAZ W
29-08-2004, 22:39
Neil
what is the rear brake set up on your MKII (i know its a disc brake set up) but what is it made up of?
RS2000CUSTOM
5 Year+ Administrator
30-08-2004, 19:01
Well mine is
Peugeot 405 rear disc
Rallye Design ally bracket
Sierra non vented calipers
xr4x4 handbrake cable
Mintex 1144 pads
Dont need to tell you Gaz how well my brakes work now do I ?
Oh and you will need an inline bias valve to turn rear brakes down !
GAZ W
30-08-2004, 19:20
dave
what model sierra did the calipers come off mate?
RS2000CUSTOM
30-08-2004, 19:23
A Ford Sierra !
Banishit
30-08-2004, 19:24
sarcy git lol
when I was looking they are the ones froma DOHC version sierra I think
85-88 2.8 XR4x4 ones
89- 2.0 DOHC version
87-89 Granada 3 2.4 & 2.9
85-87 Granada 3 2.3 & 2.8
RS2000CUSTOM
30-08-2004, 19:28
ALL Sierra non vented rear calipers are the same !!
ME SARCY ? Never - lol lol lol
Tim
30-08-2004, 19:32
pmsl
RS2000CUSTOM
30-08-2004, 19:34
Banishit
they are the ones froma DHOC version sierra
Would that be the Double Head Over Cam ?
Banishit
30-08-2004, 19:34
I have found them on the mainland or over there LOL for £25 each 2nd hand best I can get ?
but how much are the brackers for them and do you need the original carrier brackets Dave ?
do the 405 disks fit straight on or do they need turned down a bit, are they the ones from a 88-96 1.8 1.9 ?
Brian
RS2000CUSTOM
30-08-2004, 19:38
Brackets from RD are £70 (nice bit of kit though)
You will need caliper carrier bracket
405 disc supplied by RD does not need machining but flange on halfshaft needs to be turned down apprx 1mm
And you will need to fit longer rear wheel studs
Thats about it realy
Banishit
30-08-2004, 19:38
RS2000CUSTOM
Banishit
It wood over-zealous 2 fingered gusset typist
GAZ W
30-08-2004, 20:11
Thankyou david for that very informative information
RS2000CUSTOM
30-08-2004, 20:13
No probs little bloke
GAZ W
30-08-2004, 20:37
im not little , its just that everyone is bigger than me
Kel
30-08-2004, 20:37
would cossie ones be ok ?
as per
Error | The Ford RS Owners Club
http://bbs.rsownersclub.co.uk/showthread.php?s=&threadid=64728
