URGENT what size pin stripe?
  • URGENT what size pin stripe?
    What size is the pin stripe that goes around the rear pannel & is the stripe satin black or gloss black??
    Anyone got a pic of the black rear pannel with the boot open as i'm going to mask mine up for painting tomorrow
    Does this help you chris, the pin stripe is about 3-4mm wide
    Sorry it's a bit dark, Hope it's of use.
    CheeRS
    Martin
      You need a pair of these :thumbup:
      £15 the pair plus £1 P&P
      4 mm by the way - these are cut vinyl, not straight pinstripes that have been curved, and were copied directly from unused original Ford rear lamp outlines.
      Hope this helps.
      Cheers Rob.
      www.RWD-Escort.co.uk
        Where are these available?
          from the Hoarder himself
          read this post on turbosports
          pics included
