i have a 3 spoke ford aftermarket steering wheel,ford stamped on the middle spoke.on the boss it has a small blue stick with a ford oval and the following numbers 9055659 the boss is 115mm long from the back of the wheel.on another the boss is the same size but the rubber cover is only 72mm long.what models were they boss made for ?
3 spoke steering wheels ?
Originally posted by morcheen View Posti have a 3 spoke ford aftermarket steering wheel,ford stamped on the middle spoke.on the boss it has a small blue stick with a ford oval and the following numbers 9055659 the boss is 115mm long from the back of the wheel.on another the boss is the same size but the rubber cover is only 72mm long.what models were they boss made for ?CheeRS Neil
