Basically the new style of 4X4 cosworth oil pump Had failed.
The x section drilling for the spray bar which is capped off - basically the cap wasn't in well enough and the oil pressure had pushed it out causing a lack of oil pressure to the spray bar.
The top end noise was caused by the pistons hitting the head.
THis is a shock cause i paid over 4k for an engine rebuild by Harvey Gibbs and he didn't change the little end bearings.
So actual damage is all little ends, worn out
Gudgeon pins marked so need replacing. Head needs facing.
Other problems - the valve guides were replaced by Harvey in a fashion but not done professionally or correctly - this would explain the use of oil and the puff of blue smoke on accassions.
Aside from the that I lifted off just at the right time as it looks like it was about to pickup on number 4 piston and take the block out....noticed by a marking on the piston that can be polished out. But it was so close.
So the engine needs.
16 guides - annoying but at least it will be done right this time.
little end bearings
4 gudgeon pins
big end bearings
Head tidy up
16 new double valve springs
new piston rings
new wrc head gasket
And a refresh....
Gudgeon pins marked so need replacing. Head needs facing.Other problems - the valve guides were replaced by Harvey in a fashion but not done professionally or correctly - this would explain the use of oil and the puff of blue smoke on accassions.
little end bearings
4 gudgeon pins
big end bearings
Head tidy up
new piston rings
new wrc head gasket
And a refresh....
hope you get it sorted
