what should you do when youve put worthers on the wheel stands?
question for mr parker!
Very good Hally,Originally posted by hally View Postwhat should you do when youve put worthers on the wheel stands?
. Put the handbrake on
, as Hally is trying to tell you, i put Worthers on the stands, she then decided to roll off
. The CN,s did have some genuine Northamptonshire mud on them which was quickly removed, On ongoing learning process i would suggest
good job it was on flat ground ian....
sigpiccheeRS
