some ppl have got some brass balls...
scum
[quote=RS2000CUSTOM;127723]Join wires of the repeater together
When alarm goes off it will flash indicators (and repeaters)
Of course a joined wire is an electrical short and this burns out the alarm fuse and usually stops the alarm
I thought that old trick only worked on really basic 1980,s alarmsNot modern approved ones??? They took the front indicators so they might as well have the full set! poor guy
A "proper" alarm fitterist should put a Diode inline with any light or indicator feeds to stop this happening but not many fitterist do this
I suggest you all check with your alarm fitterists to make sure they have added a diode !
