Arrrrrghhhhh I can't stop
  • Arrrrrghhhhh I can't stop
    Another one joins the Hoard
    Cheers Rob.
    www.RWD-Escort.co.uk
    Rob .............. the RS magnet
      Cleaner than mine
        where did this one come from?? bottom of the solent??
          lol, could be off the napoli, is that a container i see
          good find rob, another one saved is it
            Bit of t cut and it'll be perfect!
              It's been in that container for 10 years plus !!
              It was put away by the owner when (so he says) the engine started to use a bit of oil
              T-cut and a bit of fuel and it'll be ready for the lakes tour
              Cheers Rob.
                This is it after some T-cut :
                Cheers Rob.
                  so u can polish a turd,lookin good mr h
                    If it will run (been stood for 10 years) I may try it on at the MOT station and see what happens
                    Cheers Rob.
                      Your N/S outer and probably the O/S inner h'lamp are ****ed are they not, and mister tester ought to fail that, but it's surprising how well it's come up
                        Looking good there Mr Elbow grease
                          Plenty of spares in the hoard
                          It wants a set of tyres on it too, and front brakes, and rear brakes, and a master cylinder and a weld on the n/s sill, and, and , and
                          But a car with an MOT is worth a LOT more than one without
                          Cheers Rob.
                            Don't forget to leave the 24 cans of Stella in the boot, with a little note on the top saying "thank you mister MOT man"........
                              looks good rob, amazing a bit of hard work and it transforms it
