Everything seems to be against me at the momen wit getting the car back together and running , i am seriously getting p155ed off with things now , cant see it running for anothe few months .
Firstly, cant seem to get a spark from the coil and no ign light on the dash i have traced all wires and everything seems to be correct , after trying to start it i notice loads of oil on the floor , its coming from the oil cooler , that is located behind the radiator so the rad has to come off for about the 20th time , i have also got the servo and bracket back on today then come to refit the calipers and notice i have the struts on the wrong sides ( caliper would be sat at the front of the disc) , so i now have to take all the suspension back of and refit it the correct way around , this took me ****in ages to put on in the first place, istruggled like hell to get the tca's into the bottom of the strut on me own
will the struts separate from the TCA's easily enough? this is my biggest fear that the wont, and i will split the gaiter holding in the grease . if i have to get a separator on them is there a way of splitting them without fouling anything?
why the **** didnt i realise at the time i was putting them on the wrong sides
