My Kent Cams X-Drilled cam is leaking oil !!
It is coming through the camshaft bolt ????
Looks like Kent Cams havnt blanked off the drilling down the centre of the cam
Need to call them Monday
Will let you know how I get on
Other then that engine sounds fine and only minor bits n pieces left to do
