poly bushes
  • poly bushes
    Hello again,
    how easy (or hard) to polybush the rear of a mk 2?
    Thanks
    Lee
    easy apart from the back one on the spring hanger petrol tank side ? if you have the std petrol tank otherwise not bad
      I would also like to know how hard it is the do the front end , as iove got all the front end poly bushes waiting to go on , just waiting till ive had everything powder coated
        The top one on the spring hanger petrol tank side surely?? At same time knock out the bottom shackle pins and replace with bolts. Life will be a great deal easier next time the spring is removed and the shackle should never need to come off again. Has anyone ever been supplied with a correct poly bush for a standard tramp bar rear eye (axle end)? Most suppliers seem to think a parallel bush will fit when the bar "eye" is heavily chamfered on the inside. The same bush does seem to fit the TCA inner, that is also chamfered, but not the tramp bar rear. Front end easy on std car? -but with MK1 TC ARB on MK2 for better handling, TCA can be near impossible?
          sorry yes the one nearest the back not front having a senior moment LOL
