fire extinguishers
  • fire extinguishers
    who has one in their car & what size is it? i know i should have a few of them by now for peace of mind
    totally agree, i had one lost to a fire, if i would of had a fire extinguisher it would of been a different matter.
    i carry one under the seat, dont know what size but it fits there, i wrap it in foam to stop it from sliding around.
      i carry one, im accident prone set my dad on fire then the mk2 whilst burning off underseal............
        "yo dad"
        "wot son ?"
        "nothing" !!!!!!!!!!!!!!!!
          I got one from Burtons with 2 nozzels and 2 pull cables. It mounts in
          front of passenger set with a bracket and 2 clamps. Think it cost £100.
          cheers James
          MK11 member 356
            Have 2 handhelds in the car: a 4kg Halon (yes the old good stuff) and a 6 kg powder if no.1 should fail ...
              Got one under the seat
              CheeRS
              Martin
                Yeah ive got one under the drivers side shelf.
                  yep, carry one too, in the glove box, it is mounted on a bracket, not sure what size exactly, but some where near the size of one of spence's cans of hair spray.......... quite large i hear you say??
                    This is the one going in the black beastie, an electrical 4kg jobbie
                    plus a couple of hand helds.......
                      i have a 2kg tripple F ..... water based foam, hand held secured infront of drivers seat cross member, bolted thro floor, and 1.5kg dry powder on passenger side incase of electrical fire....cant use FFF as water based
                      might seem a lot but i once stumbled across a car crash where car was smoldering then caught fire and boy did it go quick....
                      RSOC No: 14406
                      RSMK2 No: ***
                        Might have to get myself one of these..............
                          I always have the missus follow me around in one of these........
                            you can use a water based extinguisher on car electrics, its only 12V. the issue with water is the risk of electricuting yourself once you stand in the puddle, not a great worry with a car battery. may blow a fuse??
                            can some one do this, as an experiment??
